On this SB 9 is a collet closer that does not work. It will tighten the collet but it will not release with handle. It looks as if something is missing. It was on the lathe when it was rescued from the scrap pile. It looks as if someone had used it to cut small metal tubing as a piece was still in the collet that was on the machine. I have rebuilt the lathe and this is the last item. The closer was made by Hardinge and there was a Hardinge boring bar holder also on the lathe. I do not know if the closer was made for the SB because the brace arm has had an extension added. Any help would be appreciated.
