- Dec 18, 2012
- 39
So this is sort of totally off topic, as it does not relate to machining .. Maybe a little electrical. I have a basement HO Scale Model Railroad. (14x26 ft in area) I have been having problems with Two engines. One engine has a QSI Sound decoder which has a glitch in the lighting system. Also this engine was hesitating and finally it just stalled and refused to move. On taking the unit all apart, I found there was one axle in the rear truck that had got overheated, and it had warped so bad it could no longer turn. I found Athearn parts fit a Life Like Engine, so the axle was replaced, the wiring for the lights re-routed and now it is running fine.
I then moved on to engine no two, but I won't bore you with all the details. So this is a little insight into my day.. And as many of my day are Railway orientated, that is a big reason why I do not add to the postings very often.
I enjoy this site. I do have a little Unimat DB200, and I do hope to get to doing some lathe work soon.
Thanks to all that contribute to making this site so enjoyable.
