What Are These And Some Large Tooling Pictures.
FWest
May 31, 2013
50
Picked up a couple boxes of taps and some other stuff. Some massive gear, doubt I will use. Curious what was made with this stuff. Must be 15 taps 7/8"-18. A few of the larger taps have set screws.
Not sure what some of the items are ?? The first picture has a 3 cutters of some sort and 3 large nuts, split on the inside, double on the outside. The second is some of the larger taps and a few huge ez outs, ect.
Well, I see two large easyouts standing up and smaller ones laying on table for removing broken bolts from holes. most of your taps are 4 flute, these are best used in a tapping fixture and they will not self center and a 3 flute will.
I most likely wrong but I think the 3 things that look like nuts are ajustable thread gauges. At first i thought they might be Columbian nuts but they aren't.
I think that the 3 cutters inside the hexagonal shapes are called "hollow mills"
Brian
