- Jun 12, 2014
- 4,821
Actually I think the odds are quite high, when you consider that it is a production run and the distributor often will get stock from the same batch. I have seen the same issue with Dorian in the past with regard to their QCTP and holders, let alone they kept changing the design of their holders. When they put together their kits, it was whatever they had on hand. I considered buying a Sierra America Arbor, they weren't inexpensive and I recall similar reports to high runout (TIR), and I did not want to fork out $$ for their high precision saw arbor line. I made my own and the TIR was about 0.001" and the holder cap to arbor clearance is a close fit (0.0005") that it holds the saws very true. I might suggest you call the company directly as they state they have a "limited" 5 year warranty.
General Purpose Reach Arbor SA-3L (Set - .625-.1.000-.1.250 dia)
Description Set includes one of each: SA-625, SA-1000, SA-1250 Most accurate general purpose arbor sold .001 SQUARE shank to cutter locating area “VIBRA-CORE DESIGN” allows for most cutter vibration to be absorbed through our special heat treating process Deep low profile caps g
sierraamerican.com
