- Jan 22, 2022
- 128
Hey guys. I just traded for a Wellsaw 58B. I’m starting to realize it needs more TLC than I originally thought.
Does anyone have photos of the following?
Auto shut off switch? Mine has been “repaired” with a nail.
The table like the blurry image I found online. I’m mostly interested in the top of the table and how the original was cut for the blade to fit in it. I plan on making it on my CNC plasma cutter.
And I believe there should be an extension that bolts onto these two bolts.
Also, my vise screw does not seem right. It gets jammed up sometimes and won’t properly hold the work (sometimes). I feel like it needs some thrust bearings or something. Does it look assembled correctly?
Thanks in advance!
Thanks in advance!
