- Aug 6, 2015
- 3,916
These are the things I have found needing so far:
- First priority is to decide on what VFD to buy. I was made aware that a static converter is less expensive, but reading on those, they could heat up the motor, power comes down... I do not mind spending a little bit more on a VFD if that works better than a static unit... Just need to figure out which one. If I do decide to try the static converter, @matthewsx mentioned having good experience with those from North America Phase Converters
- Repair oil lines
- Clean and check everything
- Power draw bar. Being tall must have been a requirement for working in a machine shop . I need something to avoid having to use a ladder to get to the drawbar!! I have seen different setups. Some cool designs using a butterfly air impact wrench. I am exaggerating of course... have not even tried to reach the drawbar...
- Replace all metal emblems/badges... You can see the one for the model and serial number... all gone...
- There is one knob for the Y axis lock that is not original... I think... need to check photos of other machines
- Z-axis servo motor... Lazy? Yeah... If I can find a motor to drive the knee, without breaking the bank, that would be great.
- Downloaded Owners Manual
