- Nov 5, 2019
- 223
I bought a couple of zero flute Weldon c/sinks with the pilot on the bottom. I mainly use 1/4, 5/16 and 3/8 flatheads so I thought these would be useful. When using them though I found that they cut well at first but if you withdraw the cutter to check the depth with a bolt, then continue for a little deeper cut, it just sits there and does nothing, won't cut further.
Is there a special technique when using these? I running the drill press as slow as it goes, mild steel, plenty of lube.
Thanks
Thanks
