- Dec 28, 2022
- Location
- Dallas, TX
I would appreciate some advice from those of you who have experience welding or brazing aluminum: I have made a side mount license plate for my motorcycle, and I am looking to assemble the pieces together. I would either need to weld the pieces together or braze them. I have made the small brackets for reinforcement otherwise vibration and wind forces can fatigue and brake the main bracket from the license plate holder. I have both a brand new mig welder with a spool gun, and a torch with aluminum brazing rods. Problem is, I have never welded anything nor brazed aliminum!
Brazing the main bracket to the license plate holder would be easy. I have machined a ~1mm groove in the plate so that bracket will stand on its own for either welding or brazing. I am trying to figure out how to fixture the two small reinforcement brackets to weld or braze. I suppose I could tack weld them in place and then weld, but brazing may be more complicated since heating the assembly up may melt the braze in other places while I work to braze the pieces in stages.
The main plate (largest piece) is 1/8" think (~3mm) and the brackets are 3/16" (~5mm). Any recommendations on the best approach considering I am a complete novice to both methods?
