- Mar 17, 2018
- 1,400
If that is an endmill, other benefits would be that it would push the burr down instead of pulling it up. Also, if you are cutting a fragile material that is prone to chipping you would use a sacrificial backer, the endmill would push the material down into the backer, instead of lifting it up off of the backer.Sometimes reamers are made with flutes like that to avoid hogging in, and made spiral so that they can be used in holes with keyways or other slots, etc.
