- Feb 21, 2022
- 779
Punching requires precise tooling whatever size hole you are producing.I'm referring to hole tolerance not the size of the hole. When punching off from strip, you have to worry about things like strip width, drift, twist, feed speed, punch speed, tonnage, etc. It isn't just about the size of the relative punch size that we need to consider here when determining cost.
Examples:
Precise punching requires close width tolerances so the web can pass through the die guides without drifting too much and not binding.
Loose tolerances require less setup time where as closer tolerances require more time.
Closer tolerances may require pulling more punches as the tool wears.
More tool changes either requires more sharpening, or more tools.
Don't want to sharpen as much? Get better tool steel = more money.
I could go on about oils for loose, fast punching vs. slower, precise punching.
Cleaning web oilers, rapid feeder settings, etc. require different levels of maintenance, changeover, operator training and settings.
In other words, different tolerances require different process parameters, even on the same machine.
This is absolutely true. If you get paid for scrap, and at the volumes you need to be profitable in the fastener world, you need to get paid for scrap or you are throwing profits away. To tie this to my assertion about cost. The amount of scrap you make depends on well your process is defined and how well you execute that process.
We have strayed off track, sorry to derail the conversation, but it is an interesting conversation because this not only applies to the humble washer, but to the most complicated assemblies you can imagine.
The piercing process will produce unacceptable burrs well before the hole size changes so whatever size hole hole you pierce the parameters are the same.
The process will either pierce the hole first then blank the diameter using a pilot to centre the hole. Or a compound tool that produces hole and O/D in one hit.
I expect the reduced tonnage required to pierce a smaller hole will compensate for a few thousandths of scrap around the hole slug.
With the same O/D punch and a smaller I/D punch - both still using the regular clearance on the dies for the material spec, the process is identical except for a reduced piercing and stripping tonnage.
