- Dec 18, 2019
- 6,464
Thanks!That description sounds like more of an overextrusion issue. Maybe try a test print with the extrusion multiplier set to 99%
Have a look at this thread.
PETG Boogers or Blobs or Artifacts
So I am not new to printing (printed ABS for years fairly well) but I am new to Prusa and PETG. I bought some of the Green transparent PETG filament f...forum.prusa3d.com
Particularly this post by rob-l6. It seemed to help some folks having similar issues:
Posted by: Rob-l6
Try these settings, works for me and many others ...
Retract Length = 0.4
Lift Z = 0
Retract Speed = 35
I'm not experienced in this stuff, but jeepers, it was only chance that I noticed a little booger above the surface. I had actually paused the printer to try to cut it off with a razor blade. It worked once, but the printer generated some more blobs. Eventually the nozzle crashed into it.
I got one thread pitch higher on this print before it took a dump. It's not because things aren't adhering to the plate. Actually, had difficulty removing the brim! It was adhering very well. But prints don't like getting hammered sideways, especially 6" up.
Ok, added in those settings. Also adjusted the variable layers to around 0.2mm around the threads, 0.3 everywhere else. Resliced and the estimated print time is just around 7 hours. I will give it another try. Hope this works, because this really is exasperating! Not to mention collecting 100 gram paper weights.
