- Apr 12, 2011
- 3,488
I just bought a Phase II dividing plate kit for my 8 inch rotary table to make the needed change gears for my Logan lathe. After making a scrap piece I discovered that the plate for the 64 hole circle is made incorrectly. It only has 63 holes. I just want to alert anyone that has recently purchased a Phase II dividing plate kit to make sure they have good plates. It appears that the this is a wide spread problem with the new plates. I also found that all the other hole circles are correct, it was just the 64. I just wanted to alert you as you may not notice this error if you do not use that division in the plate right a way. I also discovered that the a 63 division is not of much value either. Good luck everyone.
