WANTED: SB Heavy 10 Rack Pinion Gear Shaft
Gitman
Feb 19, 2024
4
I am in search of the part labeled #32 in the attached diagram. It is for a 1977 10L with a standard size shaft diameter-stamped "s" on the end. Any leads would be appreciated!
Try this: Heavy 10 Parts
There appears to be a really nice pinion gear as well as the other parts you need.
You could part out the rest and probably break even.
