- Aug 6, 2015
- 3,901
Figured I will start my own thread...
I am a newbie and have not spent a lot of time using my milling machine until recently. Within the next year, if all goes well, I will be adding a metal lathe, CNC plasma table, and a few additional tools. Currently in the process of turning my G0704 into a CNC milling machine.
Anyway, I needed to make a dust cap for a coffee grinder. Since I do not have a rotating table, nor a wood lathe, had to improvise with what I had. It was fun, and I had to resist buying a wood lathe for this project. I figured that for the amount of use that I will give a wood lathe, I can just wait and use that money for the metal lathe that I want... I have seen many folks using metal lathes for wood projects when the need comes up... Do correct me if my perception is off.
Here are the tamper and smaller cap I have, and what I wanted to match with the new (larger) cap.
I wanted to make a cap like this one, only larger...
Ordered the wood, cut to size. Since the cap was larger than any of the wood blanks I had, I glued two pieces together...
Up to that point, all was fairly easy... then I used the milling machine to make the cap completely flat and to add the edge. Making this cut was interesting, to say the least, without a rotating table... took awhile, lol.
Checking fitment...
Final product (I gave it several coats of clear gloss polyurethane later):
That is all for now. Hopefully more projects to come as I finish the CNC conversion...
Checking fitment...
