- Apr 28, 2014
- 3,590
OK, I've got a strange one this morning. I was up in the shop attic putting some stuff away,
came back down, sipping some coffee, and one of the two (4) lamp fixtures on the ceiling went out/off.
There are two of these in the ceiling controlled by a switch over at the door.
The far one is fine, the near one is out. I removed the fixture and tested the voltage at the line.
84v is all?!? Why would it be 84v? I've attached a basic schematic and a pict.
Circuit is on a 15A breaker, and controls these two, plus (3) flouresents on a switch, and the outside LED,
all joined up at a junction box above the circuit breaker panel.
I KNEW I should have re-wire the garage when we were moving in and it was empty. This place has
been a nightmare in regards to wiring. I'll have to clear out a bunch of crap to take up the OSB I laid
down two years ago. *SIGH*
Thanks in advance as always.
