Well, if you have both, maybe... both spindle readings. A hand mic would be fine. Iam thinking about trying to design a ring light that will clamp around the outside of the VN spindles , so hundreds of an inch should work.. Not sure if the VN 12 and VN 16 are the same OD. Would like to make one that could be a universal fit to both machines...
Thanks for any info you could pass along.
Glenn
