Would a six inch vise fit this mill nicely? I had a four inch on my grizzly but it had a slightly smaller table.
Not trying to derail the thread but a quick question. What material did you used for your table covers?I've been trying to find a couple of pictures for comparison.
Here is my Glacern 5" on my PM935TV.
Here is my Kurt D-675 6" vise but not a very good shot for dimension or size relationship.
Here it is cleaned up.
Personally, both sizes work well on this size mill table but I usually leave the Kurt on it.
Mike
Nothing fancy, just some neoprene rubber from McMaster Carr. I had to order some for another project for a gentleman so I ordered a bit extra just to try it out. I like having the rubber so if I drop a part or for setting tooling/measuring instruments on it isn't metal on metal. I was worried about hot chips melting into them but so far after nearly 4 years they seem to be fine. On occasion some hot chips will stick but I simply lift the rubber cover up and brush the chips into the garbage can then wipe down with a rag and they look as good as new.
Mike
