I've spent the last couple of weeks getting my new PM-25 setup. I trimmed the head today and went to setup the vise that I had. The vise is a 4" vise with precision movement in X and Y axis. I inherited it from my father so I don't have a clue as to make, etc. Clamping locations are on the sides and one end. However, when I mount the vise with the jaws parallel to the X axis the end clamping location overhangs the table and reduces Y axis movement. I can turn it 90 degrees and it appears that it will mount just fine.
My question is, does this affect anything in the long run? In every video that I've watched, the vise jaws DO NOT run parallel to the Y axis, so, as a newbie, I need to know if this is a problem.
Thank you.
Denny
Thank you.
Denny
