- Dec 18, 2019
- 6,464
@ErichKeane thanks so much! Think I'm going to see if I can set up my mill to do the inside of the nut. It looks pretty rough there. Seems I have acquired yet another project!
There should be a pair of socket head cap screws from the bottom holding it down.Had some time to look at this. If I understand correctly, the fixed jaw has to come off to allow the nut to slide out. Once the nut comes off, then, if desired, the screw can be removed. I moved the screw some and found there was a bearing unit in the housing.
How does the fixed jaw come off? I've tried tapping it with a small machinist hammer (brass faced) but it isn't moving at all. Is it just a tight fit on the rectangular key? No hidden fasteners? Just a much bigger hammer?
Given how hard ball bearings are, I think you may need to grind it.Is it possible to cut a ball bearing in half? How would one hold it?
