- Aug 1, 2019
- 339
I see that there are no threads in this category, so let me be the first. As I said in my introductory post, I am into British cars and along with my son ( Daniel ) and a good friend of ours ( Allen ) we have been Vintage racing a 1971 Triumph TR6 ( our friend's car ), a 1961 Mini Cooper ( my son's car ) for 20 years.
Our friend bought the TR6 as a very ugly poorly prepared car and we spent the first 5 years of racing getting the car to be fast and reliable, but it was still ugly. We then did a multi year frame off restoration on the car and cured it's ugliness! Since then we have worked on additional modifications to improve the car. I do the design work, machining and some fabrication, Daniel does most of the fabrication work and builds the engines and gearboxes, Allen brings the artistic eye and planning as well as helping a lot with the wrench turning.
My son, during this time, converted his bone stock Mini into a bone stock race car and started vintage racing also. ( He started racing when he was a senior in high school back in 2001 ) He then proceeded to build the Mini into a very competitive car and was able to achieve several “first in class” finishes. By the way, Allen has also been able to achieve several “first in class” finishes.
Daniel has since acquired a 1969 Triumph GT6 Vintage racer and is rebuilding it to be fast and reliable also. The GT6 should be ready for the track this May so that will be a whole new adventure for us as the GT6 and the TR6 run in the same group so for the first time Daniel and Allen will be racing each other!
The reason that Daniel and Allen can afford to race is that we do most of the work ourselves, everything except engine machining and paint. If there is anyway that we can make the part we need, we make it instead of buy it.
Among the many components that we have designed and built are:
Richard
Allen's TR6 and Daniel's GT6
Daniel racing Allen's TR6 at Blackhawk Farms Raceway
Allen, turn 13 at Road America
Modifying a GT6 rear upright to take a stronger spindle.....a safety improvment.
Fabricated cold air box with velocity stacks.
CNCing a starter mounting plate for the GT6
Carburetor sleeves for the TR6 ( These sit under the velocity stacks )
- Carburetor inserts
- Fluid catch tanks
- Cold air induction box
- Windshield
- Front air dam and brake air duct scoops
- Seat mounts
- Rear oil seal plate
- Master cylinder mounting plate
- Starter mounting plate
- Pulleys
- Cooling system filling point
Richard
