Vintage Motorcycle Reproduction Hub
Is this the thread you mention in your sarcastic complaint?
What size should the axle be?
What is the question you want answered?
Prior to using remarks as you have, please ask a direct question with a bit more info on your intentions.
Jason
H-Mer's
websites working again.
just logon.
think i'll start at beginning with why i picked
that TYPE of bearing when somebody shows up.
Have A Nice Day!
machinists
it's a made from scratch hub.
it takes a 18 x 2.125 36 spoke rim.
flanges will have 36 little holes in them.
flanges for spokes just go on hub tube like
45 records going on record spindle.
then they get welded on.
this is a simple project.
can i make it in 3 pieces?
tube and a cap on each end?
caps about 3/8" thick.
i kind of remember they weld it on the lathe to keep it true.
bob
machinist
here paint of tube and caps
not dealing with bearings or flanges yet.
bob
shelly
this project was marked case solved and filed away!:)
i did leave out the updates in between.
saw the machinist, described what i wanted to make and
made one little drawing for him.
he's ready to make it when i'm ready.
i don't know if i'll bring up the lacing distorting the
bearing bore.
he might start yelling at me!:)
have a nice day!
hobby machinist's
this thread is still open.
the project had been shelved after basically
figuring out it was doable.
i want to be able to make a replica of
1920's or 1950's motorcycle.
the powertrain will be lawnmower engine,
jackshaft and rear sprocket.
have a nice day!
