- Jun 26, 2014
- 619
I'm looking at repairing an old machine vice that came with my mill when I brought it. I don't really have a need for it but figure I might as well tidy it up.
Once dismantled the dove tail, gib, jaws, etc all look in reasonable order, but the feed screw and nut (not sure it that is the correct term for a vice but you know what I mean) are stripped and need to be replaced. It's is about a 1/2 inch, 10 TPI acme thread.
While I could have a go at single point threading a new feed screw I don't think turning an internal thread on a nut that small would be an option. So I need to source an acme tap or a nut and some screw rod which I think will be problematic where I am (still need to check but I imagine it will be a internationally order off ebay - and with the current postal strike is South Africa who know how long it will take to get here)
The alternative is to just use a M12 thread - I have threaded rod and the necessary taps and dies for that. I know a 'V' thread is not recommended for a drive screw but what I would like to know is just how bad would it be. Would it work or is it a total no-no?
