- Feb 8, 2014
- 11,145
I am pretty sure this feature is also built into the VFD, I am just not seeing it.
Are you using a GS2 or GS3 VFD?
I will be using a Hitachi WJ200-015SFAre you using a GS2 or GS3 VFD?
Are you using a GS2 or GS3 VFD?[/QUOTE
GS2.......I think that the safety concerns of OSHA & others regarding hard wiring safety circuits still apply. (Yes there are safety qualified PLCs.....) but, for simple reasons that I gave, all of the given safety interlocks are accounted for in the original equipment, To me, the use of these & the isolation of signal to the VFD with the ice cubes is all encompassing. But, I wonder what the GS3 has as other features, considering your question.
The only professional installs I could find that use complicated interlock and relay systems are those that also use PLC's. Complicated interlock systems were used on older VFD's, modern ones have all the controls and the like built into them. For manual machines, they just add an extra layer of complexity and could make the system less reliable, and certainly much harder to diagnose problems.
The reason for my question was just to look at a manual that I have. The GS3 is a vector drive, and does have a few more features, but I don't think that there is much difference in the control functionality. Both of the GS drives will pretty much work like joshua wants. The control power relay with 2 button control is still really the safest IMHO
