- Dec 18, 2013
- 87
•this is a little off subject and I know I could have done some research but if I'm posting I might as well ask. I'm installing a coolant system. I'm coping a diy I found on YouTube 5 gallon bucket and fish pump. some of y'all might have seen it. My question is what are y'all using as far as water soluble oil? I did a bit of research on this and pick up what had the best reviews on amazon, Sta-lube anti corrosive soluble oil it's a CRC company I've used a lot of their products and like what I've used. I'm not opposed to using something better. Also I was wondering if y'all are using anything to keep the water from getting funky and nasty I've seen where people are using chlorine tablets I can not see where that can be good at all I've also seen where guys don't use anything at all. I was thinking maybe a UV light like they use in hot tubs. Am I wasting my time worrying about this?
Thank you in advance
Dennis
I would avoid the chlorine tabs. Chlorine is an oxidizer and you are very likely to end up with a nasty corrosion issue on your hardware and/or parts.
I have heard some people speak of KOOLRite 2290 and it having excellent resistance to crud. I don't have any personal experience with it.
