2.2KW corresponds to a 3HP motor, so it is oversized but that generally will work. You will need to be sure the vfd 220V single phase in, and 220 ( 3 phase) out. 220, 230, and 240V are all close enough to be considered the same.
A vfd needs to be directly wired to the motor, not through any switches, contactors or other intermediate devices. Ideally with fairly short wiring. You’ll want to run some control switches to the vfd, although it is possible to just use the vfd front panel. You will need to configure (program) the vfd.
Several folks here are very experienced with vfd setups and may add more.
