- Jun 12, 2014
- 4,811
It is clear that it is an output device failure, at this cost level they do not repair the VFD's, larger VFD's are more modular and often specialized for the application so pays to have them repaired. A new Automation Direct 2 Hp VFD are $200. It appears you are using 3 phase input model which are built for lighter duty then a single phase model. As mentioned the technology has advanced significantly, buying the same older model is probably a poor choice, you really need to be buying one with some form of sensorless feedback motor control, to be doing low speed drilling and tapping will be very taxing on the VFD/motor. I would limit the motor lower speed to 20Hz. The applied torque will still be 1/3rd of what a pulley speed reduction would be for the same spindle RPM.
