https://www.wolfautomation.com/vfd-3hp-200v-single-phase/ Says they have them in stock. Could just call them to find out.
Anything you might have that would apply to my application would be much appreciated. All the info you've posted made my lathe conversion possible!I typically recommend 3 wire control with momentary buttons for stop and run, and a sustained FOR (no connection) or Reverse (connects to the 3rd input). Also Automation Direct has some the GS20 series which are easy to setup. If you have a question on parameters, I can give you a hand.
