Vevor 7x14 lathe parts break-down
steelcat
Oct 26, 2023
82
This is for a Vevor 7x14 lathe.
It came from Vevor so it should be fairly accurate.
I thought that Vevor owners could benefit from it.
It was like trying to pull hens teeth getting Vevor to give it up.
  • 1_1701671750933.pdf
I just a mini lathe in November.
The company finally said there is no parts list.
The lathe has a lot good upgrades but manual is not good.
Thank you I downloaded the parts list.
Dave
Glade you found it useful!
It only took me 3 months of slinging emails back and forth to get them to give it up. Vevor will work with you if you play the game there way. I am very satisfied with mine once I got the bugs worked out.
I think worst part on mini lathes is the 4 way tool post . Most have do not know you shim the 4 way tool post.
I put Aloris on mined.
Dave
Wow! If that's the worst thing you discovered about your mini lathe, then you are one lucky SOB. :grin: :grin: :grin:
There was a one other things carriage lock I add.
Dave
The motors are garbage and crap-out/stall when parting!!! Other than that when u get bugs out and fairly useful. Mine arrived very nice in the woodin crate with no flaws, Other than that the funky TS won't align itself....
