- Jun 12, 2014
- 4,816
I would use an annular cutter, use a 3/4" R-8 collet to hold it, I use them all the time in various steels and they fly through steel plate and rod. Run around 300 RPM, use continuous feed pressure do not peck at the work. Use some cutting oil. I get very close tolerances using them, but if I need an exact ID. I cut the hole slightly under and then for an exact ID I finish with either a boring bar or boring head. I would not use that Harbor freight cutter, a decent annular cutter is much more rigid. Once you start using them, you will never go back to regular hole soles in most applications.
Hougen Rotabroach 12136 1-1/8" X 1"
CHAMPION RotoBrute XL100 or XL200 1-1/8"
