- Feb 2, 2014
- 1,068
I made and installed the cam shaft (less the cams) in the housing to determine the distance between centers of the cam and crank shaft.
In order to use just two timing gears the cam gear would be over 3" in diameter. It would stick way out over the side of the engine and be in the way of other things. Besides it would look awful so I decided on a double reduction gear train.
The gears are not shown in any order and two of them will be locked together on a single axle.
Tomorrow I hope to have them mounted and meshing nicely.
Thanks for looking
Ray
Thanks for looking
Ray
