- Sep 27, 2014
- 3,123
Quick question: so I got this 8" RT delivered UPS the box wasn't beat up to bad , got the RT out of the peanut foam , cleaned the protective grease off best I could.
Turning the table by hand "worm disconnected" seems to be a tighter spot when rotating, one area takes a little more pressure to rotate it. I can feel it with worm ingaged also.
Do you think this will go away with time or is it going to be a problem
What type oil goes in the ball oilers , one on the worm housing , one on table side, ? Spindle oil I hope
Wasn't mutch info in instructions , is this one of those Asia things the end user needs to fix / make rite ?.
Thanks
And have a great holiday
Thanks
