- Dec 18, 2022
- 1,729
That is what it was made for.@CJ5Dave is this for ink use only, or can I use a lead/graphite tip instead? Is there a provision in the kit for using graphite tip?
I cleaned mine once a week when I was using them and stored them dry and empty long term. The ink went in the reservoir and the nib has a plunger in it with a wire which dropped down through the point which would push the plunger up and allow the ink to flow from the reservoir. You haven't lived until you have used these on Mylar, tape it down, pour pounce on it, rub the pounce around thoroughly to etch the Mylar, then brush it off and begin. All the guys that use to do ink work had drafting dots on their triangles and scales to space them off the paper to prevent the ink from wicking under them and destroying the drawing.Could not get a picture to focus on this for some reason, but it has 0.5 mm lead for this clicker pencil to go in the head, or several refillable ink cartridges of different widths. As I recall was a big deal to clean these out every day, maybe with alcohol? It also has some little ink tips that you manually ink like a feather quill
