    Dismiss Notice
Variable Speed RF45 Clone or Geared Head?
Discussion in 'ENCO & RONG FU IMPORTS' started by Matabele, Aug 5, 2017.
  1. Matabele
    Matabele United Kingdom Active Member Active Member
    7
    8
    City:
    Cirencester
    State:
    Outside US / Canada
    -Return to Top-
    Hi folks,
    I'm looking at options for a milling machine, and one contender is this:
    http://www.amadeal.co.uk/acatalog/A...gital-Read-Out-MI_AMA45V_R8M_DRO.html#SID=376
    I was wondering what your thoughts were on this versus a standard geared head?
    I'm no electronics guy and was wondering if it would be giving up anything in terms of torque to a geared head, it has a 2.2Kw motor compared to a 1.5Kw of the geared head...is this to compensate for the reduced torque? The VFD also runs off single phase, and I understand it might be better to run VFD's off of 3 phase motor to maintain torque at lower speeds. What do you think?
    The variable speed also gives up 400rpm's of top speed over the geared head, which isnt the end of the world for me I'll be machining steel mostly although some aluminium parts and even wood will definitely be cut.
    For guys who have used this style of bed mill and Bridgeport size knee mills...should I be putting the same money into a used Bridgeport or are you guys happy with your RF45 and clones?
    Any input appreciated, thanks!
  2. tweinke
    tweinke United States Active User H-M Supporter-Premium
    245
    43
    City:
    Fairmont
    State:
    Minnesota
    -Return to Top-
    Wonder how many guys have a variable speed 45 type mill I know that Grizzly offers one here in the states, but never have seen one. Pretty sure that the common answer to your question is " Get the biggest mill you can fit/ afford in your shop" . And with no doubt that statement is the truth. Hopefully someone will chime in with the experienced answer to your question. For me the idea of having to rebuild an experienced machine is a no go due to lack of knowledge in that respect.
  3. xman_charl
    xman_charl Active User Active Member
    37
    28
    City:
    vallejo
    State:
    California
    -Return to Top-
    have enco mill similar to that one.
    not variable speed.....never had a need for it
    variable speed on lathe, yes... or always changing belts
    Charl
Share This Page
