- Jan 4, 2021
- 910
Roofing is architectural asphalt shingles. Ridge vent down the entire length. Soffits are vented the entire length on both sides and I used those vent chutes in every rafter space to make sure there was air flow from the soffit to the ridge. The ceiling is framed as, I guess you would call a tray ceiling. Walls are 8 feet, but I had a collar tie placed at the 9 foot level. Rafters are 12" on center. Low pitch roof, somewhere around a 4:12, maybe a bit steeper.I'm a contractor, I wouldn't bother putting any additional vapor barrier, the metal will be enough. What is the roofing material, is there a ridge vent?
