- Apr 30, 2015
- 11,307
OK well that's a simple fix- keep us posted
It looks like when wired per wiring plate and when motors moves all three lines in are drawing 4-5-6, are .42A or so.How much current are you getting on each leg? What rpm does it settle out at?
Alright new motor installed. Ran motor directly from phase converter and there was the similar slow running behavior. So I thought I had the leads switched around, swapped two of them and motor ran full speed.Seems to me that we had a motor that was rewound so it was only 440V. Something that was done because all we had was 440 and it was cheaper / easier. Thought that you were getting a new / different motor? I will look to see what I had found to verify coils locations after Christmas.
