Does anyone know where I can get a vblock that I can mount in the toolpost to allow me to cross drill round bar and tube on my lathe?
Sadly making one is not an option as I do not have a milling machine YET
If you mount a block on the compound and using an endmill in the chuck, mill a slot. It will be on center and as long as it is narrower than the stock your cross drilling it will be ok . it doesn't have to be a vee to work. Just be sure to square the block with the chuck.
trapper, do you have a QCTP? ( quick change tool post ) Also, what size is your lathe?
Jeff
You could drill and tap 2 holes and use a strap clamp. although a drill press would probably be easier with the same setup, depending on what machines you have.Thanks for that yes I guess simple is best, how do you secure the workpiece to the block?
