Today I did the unthinkable. Many people buy SWAG Offroad finger brake kits and then work hard on putting them together, but it seems like hardly anyone actually uses them. There are tons of videos on Youtube about putting a brake together and modifying it, but try finding a video about making parts with one. Not easy. Today I went rogue and actually USED my brake. I made a shelf for an arbor press stand. I used 1/8" (actually 11-gauge) plate.
I learned a few things. I didn't know how much a finger brake would stretch metal. I tried to make 1" high lips on the shelf, starting with a piece of plate 14" wide, and when I was done, I had a shelf that was still over 12" wide. I guess you have to make practice bends and take notes if you want to bend anything with any degree of precision.
I also learned I could locate workpieces well by holding them with my right hand and looking behind the press while I lowered the fingers. When the fingers started to push on the metal, I was able to move it around with a nylon hammer and get the bends almost where I wanted them.
The bends aren't as sharp as they could be, although they look a lot better than they do in the photo. I'm not sure how to deal with this. Offroad Swag makes an optional bottom die. I am considering using my mill to sharpen the corners inside of some angle iron pieces. I could use them as dies. The kit comes with a bottom die that has a very big radius inside it.
This is a transcendent tool. Does stuff a hobby-size stand-alone brake can't begin to do. Really liberating.
I'm looking forward to learning more about using it. Tips are welcome.
