- Mar 27, 2022
- 425
I just realized I may not be exactly right with my more efficient assessment. As noted earlier it by @JPMacG will have less voltage sag since amps will be about half. Also since amps are half you will have less loss through resistance in the lines and windings(translating to heat). I think that is what lends the efficiency boost.
Also it helps balance your load panel since it’s pulling from both legs.
I looked at a couple dual voltage motors and they have the same total wattage between 115 and 230.
