    Dismiss Notice
Upside down and backwards threading with screw on chuck??
Discussion in 'GRIZZLY INDUSTRIAL INC.' started by Mark Stonich, Feb 7, 2017.
  1. Mark Stonich
    Mark Stonich United States H-M Supporter - Premium Content H-M Supporter-Premium
    8
    3
    City:
    Minneapolis
    State:
    Minnesota
    -Return to Top-
    shows a slick way to avoid threading toward a shoulder.
    Apparently due to viewer feedback, he added this warning to his comments:
    "To all my viewers. Please exercise caution and use good judgement when running a machine with a true screw on chuck. Excessive spindle load with the machine in reverse could potentially unscrew your chuck causing damage and personal injury. Refer to your operator or machine manual for safety suggestions."
    My new Grizzly G0602 has a thread on chuck. There are a couple of clamps that should keep the chuck from coming off. But if it moves at all, the work would be ruined.
    Any suggestions? Locktite? :)
    I will make a reverse tumbler. And the threads I want to cut are 24 tpi x 1.375 OD in aluminum. Probably 7075.
  2. Mach89
    Mach89 United States Active Member Active Member
    128
    33
    City:
    Syracuse
    State:
    Ohio
    -Return to Top-
    I learned this trick a while back. Works really well. An upside-down tool is also useful for turning bronze. It helps keep the chips from flying all over the place (and down your shirt). The chips just fall down in the chip tray for the most part. Less mess to clean up.
    Sent from my SAMSUNG-SM-G891A using Tapatalk
    ddickey and TomS like this.
  3. Mark Stonich
    8
    3
    City:
    Minneapolis
    State:
    Minnesota
    -Return to Top-
    Mach89,
    Thanks for the endorsement of his method. Never thought to use it for turning. Due to the tall compound of the G0602 it can be hard to get the tip of some tools low enough with the Grizzly T10166 QCTP. This would solve that problem
    Now if I can just figure out how to lock my chucks to the spindle.
    Mach89 likes this.
  4. savarin
    savarin Active User H-M Supporter-Premium
    1,703
    113
    City:
    Townsville
    -Return to Top-
    what about placing a brass section in the clamp holes and tightening that down onto the spindle, being brass it shouldnt damage the spindle thread.
    I have just cut 2 "O" ring internal grooves in an 80mm bore in reverse, I just screwed the chuck on very firmly and took care.
  5. Mach89
    128
    33
    City:
    Syracuse
    State:
    Ohio
    -Return to Top-
    This may not be the best idea, but you could cut a couple or the flats across the threads and use large set screws. Again, probably not the best idea cutting flats on the spindle threads, but it's a thought.
  6. Mark Stonich
    8
    3
    City:
    Minneapolis
    State:
    Minnesota
    -Return to Top-
    savarin wrote;
    "What about placing a brass section in the clamp holes and tightening that down onto the spindle, being brass it shouldnt damage the spindle thread."
    Sounds good. Or better yet, leave the clamps and add 2 more holes for the brass slugs.
  7. eeler1
    eeler1 United States Dang, buggered that up too!! H-M Supporter-Premium
    137
    43
    West Sacramento
    City:
    West Sacramento
    State:
    California
    -Return to Top-
    Get collets
    Charles Spencer likes this.
  8. RJSakowski
    RJSakowski H-M Supporter - Premium Content H-M Supporter-Premium
    2,418
    113
    City:
    Barneveld
    State:
    Wisconsin
    -Return to Top-
    You should have no trouble running the 602 in reverse. The design of the two clamps is to draw the chuck tight to the shoulder register as well as preventing rotation. In more than three years on my 602 I have never seen any loosening of the chuck. (other than the tinme
  9. ch2co
    ch2co United States Grumpy Old Man H-M Supporter-Premium
    417
    63
    Mile High Colorado
    City:
    Center of Colorado 5420ft
    State:
    Colorado
    -Return to Top-
    What RJ said.
  10. fitterman1
    fitterman1 Australia H-M Supporter - Premium Content H-M Supporter-Premium
    64
    28
    Australia
    City:
    Adelaide
    State:
    Outside US / Canada
    -Return to Top-
    Ditto to what RJ said, assuming your lathe isn't modded with a variable speed drive means you're attempting to cut a thread at 150rpm (your lowest speed). Pretty hairy at the best of times. I suggest you use the method put forward in the video, its your safest option and considering you are cutting ally at a fine pitch, your depth of cut will also be small, potentially minimizing the chance of chuck rotation.
    I have variable speed drive on my G0602 (ideally its now a G0752) and I'm able to dial my speed down to about 20rpm but I prefer around 40-60rpm because I get a better finish when screwcutting. I also have a built in brake which stops the chuck within a second and I've never noticed a movement in chuck orientation.
    I made a spider once to fit the lathe, and I actually removed the chuck and work together from the spindle to check the thread on the other end of the spindle for fit a number of times. Upon reassembly no change in crosslide position was made to check for motion on first pass. I never had an issue that day.
    I think your only issue should be work stickout. If short its ok, but if long you need to support the end and work around that.
    As Mach89 mentions, an upside down tool is handy. I have a boring bar permanently set upside down in its toolholder for when boring deep holes, I run the spindle in normal direction and bore the opposite side of the bore. This way I can see what I'm doing without hanging over the lathe and upsetting something.
    If machining brasses and bronzes I make a chip deflector out of some brass shim and fit it to the tool clamping bolt closest to the working end and form it to sit above where the action is.
    This saves me spraying the surrounding area and myself with swarf.
    markba633csi likes this.
  11. John TV
    John TV United States Active Member Active Member
    6
    8
    City:
    Rosemount
    State:
    Minnesota
    -Return to Top-
    Thanks for the great responses. Didn't expect to get so many ideas, now I need to play a bit and see what works. This site is such a great resource.
    John
  12. pdentrem
    pdentrem Active User Active Member
    217
    63
    City:
    Niagara Region South
    State:
    Ontario
    -Return to Top-
    If you are not threading to a shoulder then just set the tool upside down, cut on the back of the bore hole with the chuck rotation in forward. If threading to a shoulder then threading in reverse as shown will work just be careful as already stated.
    Pierre
  13. Splat
    Splat Active User H-M Supporter-Premium
    90
    48
    City:
    here and there...
    State:
    New Jersey
    -Return to Top-
    Instead of retyping it check what I wrote in this thread. Cheers.
Share This Page
