I inherited a bunch of Erickson da180 collets and some collet chucks with no markings. There is a 1 1/2 in hex nut to hold the collet. The nut of one chuck has some markings, but they have disfigured by peening and the use of a pipe wrench to tighten and remove that nut.
All dimensions are in inches and are approximate.
minor od: 0.950
major od: 1.430
length of taper: 1.565
overall length with nut: 3.21
overall length with collet installed with nut ~ 4.75
The only threaded part is where the nut attaches. There is one keyway on the taper, and no obvious way to hold the chuck in a spindle. There are no slots to engage drive lugs.
I would like to know what taper the chuck is and if these are useful for milling, lathe or ?
Thank you
minor od: 0.950
major od: 1.430
Thank you
