- Sep 29, 2017
- 2,251
Hi @brino a.k.a Brian.@Suzuki4evr
Hi Michael,
You might consider 3D-printed gears here. Many people worry about their strength, but i) some new lathes come with at least one plastic gear as a sort of "crash fuse", and ii) you just need indexing, your use on the divider will likely never see even cutting forces if you manually set the position then lock the brake, make your cut, unlock, step, lock and cut, etc. (Unless, of course, you are generating the gears with a hob under power.)
Two offers:
1) If you can find a 3D printing service locally I could generate the STL model files on Fusion-360 and send them to you.
2) I could print you a set of plastic gears and mail them to you.
Either option at no cost to you!
If you're interested just let me know your final specifications (DP or mod, tooth count, gear thickness, bore dia., pressure-angle)
Brian
Here follow the gear diamentions for the gears I need. All gears are DP12 14.5°PA and the gears are 18mm or 0.708" thick.
24 TOOTH GEAR
OD=55.02mm = 2.165"
28 TOOTH GEAR
OD=63.48mm = 2.499"
32 TOOTH GEAR
OD=71.94 = 2.832"
38 TOOTH GEAR
OD=84.64mm = 3.332"
44 TOOTH GEAR
OD=97.34mm = 3.832"
If you need anything else from me,just let me know. Brian before you start,just make sure about shipping costs to Wellington,Western Cape,7655 South Africa. I don't want this to be a surprise fo any of us. Let me know when you know. If it is too expensive then I will take you up on your first offer of the STL model files (I don't understand any of that mind you.)
