- Nov 25, 2015
- 8,317
I just got an email that Union Tools is resurrected for the woodworking tools. And they show some dovetail gauges. I'm not buying them, don't like the design.. but the quality is quite suspect in my mind.
Here's a pic, and here's the description... To me, the top looks saw cut , not milled. If you are hand sawing, you want to make a reference across the end to show square so your saw will follow it. I generally make a knife cut and 45 knife to have the saw follow.. This would bother me if I bought it. Also I made a home made gauge so mine are narrowish at the top and match my chisel width so I don't have to calculate, these are upside down and require a lot of calculating... not what I would want...
Does it look to you like it's saw cut or milled?
Edit: from Lee Valley:
Dovetail markers and saddle squares are indispensable tools for marking out quick, accurate and consistent dovetails and finger joints.
Each marker is precision milled from one solid piece of stainless steel, with the inside surface textured to prevent slipping while laying out your lines. They ensure perfect alignment by allowing the straight and angled lines to be scribed at the same time, around corners as one continuous line.
Each measures 2" long and 3/8" thick, to facilitate marking on either edge of a board. The markers are available in the most common angles for dovetails and finger joints, 1:8, 1:7, 1:6 and 90° for the saddle square.
Union Manufacturing Dovetail Markers & Saddle Square - Lee Valley Tools
www.leevalley.com
