    Dismiss Notice
Underwhelmed By Noga Base?
Discussion in 'METROLOGY - MEASURE, SETUP & FIT' started by jmcghee, Aug 3, 2016.
  1. Tozguy
    Tozguy Active User H-M Supporter-Premium
    764
    113
    City:
    Drummondville
    State:
    Province du Quebec
    -Return to Top-
    Both of my medium sized FAT Nogas hold well on vertical surfaces but I have to be selective about where it goes on painted cast iron. If there is just paint then fine but where there is also a layer of Bondo it does not hold enough.
    Storing the bases on a steel surface with the base ON is supposed to preserve the magnets better.
  2. pstemari
    pstemari H-M Supporter - Premium Content H-M Supporter-Premium
    239
    43
    City:
    Renton
    State:
    Washington
    -Return to Top-
    Oh? I would have thought that Noga at least would be using neodymium magnets. Alnico and ferrite magnets do benefit from a "keeper".
    Sent from my Nexus 6 using Tapatalk
  3. Greebles
    Greebles United States Active Member Active Member
    20
    8
    City:
    Austin
    State:
    Texas
    -Return to Top-
    I have a Noga w/ base and it holds very well and takes some effort to pry it loose when activate. Perhaps you have a defective base?
    -Denzil
  4. ch2co
    ch2co United States Grumpy Old Man H-M Supporter-Premium
    421
    63
    Mile High Colorado
    City:
    Center of Colorado 5420ft
    State:
    Colorado
    -Return to Top-
    My mid sized Noga base holds better than any of my others from across the Pacific. Here's a list of what Noga says their bases are supposed
    to do. One N (newton) is about .25 pounds of force. So my M8 base should require about 200 pounds of force to pull it off. That force would
    be applied in a direction just opposite of the base, no pulling to side.
  5. ch2co
    421
    63
    Mile High Colorado
    City:
    State:
    Colorado
    -Return to Top-
    Sorry the model number would be DG0036. (The M8 is the thread size)
Share This Page
