We picked up a small to medium sized usa made ultrasonic cleaner from online seller ad of course, the ultrasonic part does not work.
It is 50khz and 60 khz dual frequency with tank heat.
The driver is working but the connection to transducer is bad.
Someone tried to solder it and failed.
Looks like it is attached, only the Flux was holding it, scope had many volts on the solder, zero on the transducer, gentle pull and wire with solder lifted up with wad of Flux in the middle.
Looks like transducer is attached with epoxy, difficult, but not impossible to remove.
Trying to find replacement transducer, most are 40 khz, and are different shape.
There are lots of options, looking for someone who maybe has done this before or knows how to source these things.
Sent from my SM-G781V using Tapatalk
