- Jan 20, 2018
- 5,671
Assuming .0005 - .001 interference, even a 1-ton should do the job. Getting the pin started straight is the critical part.What size arbor press would work for this? 2 ton? I think I'll have to get one.
With arbor presses, the limitation is frequently the vertical capacity under the ram. I'm currently struggling with this issue. A C broach (1/4-3/8) is 12 in. long, which stretches the capacity of a 3-ton press.
Far be it from me to discourage you from buying tools. Instead of buying a tool to do this job, try to imagine what your future needs might be and choose accordingly.
