- Mar 26, 2014
- 1,500
I am making a post for my vice. I have a 8" diameter pipe 48" long. I thought I would clean it up on the lathe to get rid of the rust and scale. I welded a piece of flat stock on one end for the live centre. (was only out 45 thousands with the dial indicator). I made three passes to clean it up and it measured 7.875 on the headstock end and 7.879 on the tail stock end. The problem is its bigger in the middle. My last pass the bit didn't even cut in the middle, only on the ends. What is happening here? I could see if it was cutting a taper, but I don't understand this.
Thanks
Martin
Thanks
Martin
