- May 16, 2016
- 1,702
Doing it for a living, definitely makes a difference in one's approach, and generally means stouter, and higher quality machines to do the work. On my 12" Craftsman I have also made good use of a file and emery cloth to get a good finish. I'm looking forward to eliminating some of those steps with the new to me TOS I've yet use. The great thing about this forum, Is that you get so many different, and valid approaches to to the same issue. Mike
Always more than one way to skin a cat.
Yes I always encourage beginners to experiment with HSS tools, mess around with with rakes and clearance angles, when I was an apprentice only the senior toolmakers could have carbide tips, there were no inserts just brazed pieces on a steel shank. I experimented with HSS and found that I preferred some tools that did not fit the text book shape, but they worked for me.
Al;os make sure your tool is on center, It's better to be slightly below than above, on center is best.Also check the gibbs are as tight as possible without binding, and make sure there is no wear in head stock bearings, adjust if possible, if not replace them.
