- Aug 31, 2014
- 50
Hi, I bought four 10 x 2 inch circular mild steel stock from our local engineering shop. The idea is to turn 4 wheel spacers for my Series Land Rover, to increase the wheel offset. The engineering shop cut it into circular shapes and I asked them to drill a 1'' hole in the center. I want to fix the stock to a 1'' shaft to turn the stock.
I have a Knuth 3Hp lathe with a 14" swing and 1m between centers. I never machined a plate so heavy.
My question: Can my Lathe handle a plate so heavy?
At what RPM should I cut?
Would it be safe to fix the plate to a 1'' shaft to machine the diameter?
When I have the correct outside diameter, I must increase the inside diameter to about 4". Should I fix the
plate in the 4 Jaw chuck to do that?
I would appreciate any comment.
Thank you,
Anton
Thank you,
Anton
