- Dec 24, 2020
- 1,070
I went to remove the chuck from my Sheldon lathe (13 x 36) which has a 2-1/4 - 8 thread-on chuck and it's stuck...I mean really stuck. I haven't been using this particular lathe long and haven't removed the chuck previously. I had the exact same model lathe, minus a taper attachment previously, and had the chuck off of that several times with no issues. I've tried all of the "this always works" tricks I've been able to find and it's not looking good....stuff like 1" hex in the chuck and gave it some impact gun hits did nothing. I took the chuck off the backing plate so I could get heat (propane torch) to the right area, as well as get Kroil on the threads. I made a 36" long bar that I drilled to bolt to two of the face plate holes and that's giving me decent leverage. I made a split collar sized for the far end of the spindle and welded a 24" bar to that so I could pull on the back plate while pushing on the spindle after getting it hot...no luck. At this point the only thing I have left to do is to try some different ways of locking the spindle (I know not to use back gear) a bit better than I can right now. I could try going hotter with an oxy/acetylene....that works well for smaller stuck bolts/nuts. I figure I'll give it another day or so of heat/Kroil/etc and see if anything works.
If not, it looks like I'm going to have to turn off the backing plate, which is doubly annoying because it's 8.25" not 8" and so far the only options I've found are about $300, which is more than what the chuck is probably worth (old Cushman likely original to the machine).
If I have to turn it off, are there any tips/tricks I should know? I'm dreading that many cast iron chips flying...ugh.
