I am trying to do a hybrid turbo build, reusing the factory turbine housing as my car has a Mazda specific flange and using a large compressor housing and of coarse using a CHRA that can flow more, I am looking to obtain 45lbs/min for my power goals. Then ofcoarse I would have to have the housings machined to allow for the bigger wheels. Being that I have no experience in machining, I am looking for advice on how I should go about doing this, and how I can find a machinist that can do this. For my plans, I plan on still usign a journal bearing housing, as it is rebuildable and cost effective. The current turbo I have is rated at about 35lbs/min, K04 turbo. Any advice would be greatly appreciated.
These are the specs of the stock turbo:
Measurements: K04
Compressor Inducer 45.1mm
Compressor Exducer 56.0mm
Turbine Inducer 50.00mm
Turbine Exducer 44.47mm
Shaft journal dimension 6.96mm
Shaft end 4.56mm
And a GT28 for reference for something I would like to get close to
Compressor Inducer 47.21mm
Compressor Exducer 60.00mm
Turbine Inducer 53.80mm
Turbine Exducer 46.82mm
Shaft journal dimension 9.15mm
Shaft end 5.97mm
Measurements: K04
Shaft end 4.56mm
Shaft end 5.97mm
